Gen 1 vs Gen 2 Dev Board Information
Critical Link has released two versions of the MitySOM-A10S Development Board as follows:
CL Part Number* Generation
80-001127RC Gen 1
80-001218RI Gen 2
*The part number is found on the first line of the label near the PCIe header of the dev board.
Generation Differences
Depending on the interfaces used by your FPGA project you may need to have an alternate version to support your design on both development board generations due to the differences noted below:
Power Switch (SW701)
  1. As all SoMs can support the 5V input type the switch was removed and pop/no-pop resistors were utilized on the dev board to set the SoM input voltage to 5V.
    1. Gen 1
      1. Switch is populated which allows for the selection between 5V VIN to the SoM or 12V VIN to the SoM
    2. Gen 2
      1. Switch is NOT populated and SoM input voltage is fixed at 5V
      2. If a 12V SoM input is required please contact Critical Link for further details.
Temperature Alert LED
  1. A Red LED was added to the temperature alert output (t_alert) from the SoM at pin D2 of J201B
    1. Gen 1
      1. No connection to D2 at J201B
    2. Gen 2
      1. Active low red LED (D201) connected to D2 at J201B
Component Temperature Rating
  1. Gen 1 (Commercial Temperature Rated)
    1. Some components used on the development board are not all industrial temperature rated.
  2. Gen 2 (Industrial Temperature Rated)
    1. All components used on the development board are industrial temperature rated.
FMC Connector J300
  1. It was found on Gen 1 that the P/N pair was reversed for FMC pins J18 & J19 compared to the Arria 10 SoC p/N polarity.
    1. Gen 1
      1. Arria 10 SoC Ball Y1 (P) connected to FMC Pin J19 (N)
      2. Arria 10 SoC Ball Y2 (N) connected to FMC Pin J18 (P)
    2. Gen 2
      1. Arria 10 SoC Ball Y1 (P) connected to FMC Pin J18 (P)
      2. Arria 10 SoC Ball Y2 (N) connected to FMC Pin J19 (N)
Transceivers/PCIe Connector
  1. It was found in the Gen 1 board that the transceivers routed to the PCIe connector needed to change. Due to this, some of the transceivers connected to the FMC connector were also changed for the Gen 2 board. The differences between Gen 1 and Gen 2 are shown below and also included in the attached Excel spreadsheet (https://support.criticallink.com/redmine/attachments/download/23998/Gen1_vs_Gen2.xlsx).
PCIe Changes
PCIe Interface Gen 1 Gen 2
PCIe (J500) Pin PCIe (J500) Signal Name Baseboard Net Name Arria 10 SoC Ball Baseboard Net Name Arria 10 SoC Ball
A11 PERST_N PCIE_PERSTn_3V3/nPERSTL0_LVDS2A_19p AB11 PCIE_PERSTn_3V3/B2A_AB11 AB11
B14 PET0P GXB_TX_0_P AG28 GXBR TX 0_P W28
B15 PET0N GXB_TX_0_N AG27 GXBR TX 0_N W27
B19 PET1P GXB_TX_1_P AE28 GXBR TX 1_P U28
B20 PET1N GXB_TX_1_N AE27 GXBR TX 1_N U27
B23 PET2P GXB_TX_2_P AC28 GXBR TX 2_P R28
B24 PET2N GXB_TX_2_N AC27 GXBR TX 2_N R27
B27 PET3P GXB_TX_3_P AA28 GXBR TX 3_P N28
B28 PET3N GXB_TX_3_N AA27 GXBR TX 3_N N27
A16 PER0P GXB_RX_0_P AF26 GXBR_RX_0_P V26
A17 PER0N GXB_RX_0_N AF25 GXBR_RX_0_N V25
A21 PER1P GXB_RX_1_P AD26 GXBR_RX_1_P T26
A22 PER1N GXB_RX_1_N AD25 GXBR_RX_1_N T25
A25 PER2P GXB_RX_2_P AB26 GXBR_RX_2_P P26
A26 PER2N GXB_RX_2_N AB25 GXBR_RX_2_N P25
A29 PER3P GXB_RX_3_P Y26 GXBR_RX_3_P M26
A30 PER3N GXB_RX_3_N Y25 GXBR_RX_3_N M25
FMC Changes
FMC Interface Gen 1 Gen 2
FMC (J300A) Pin FMC Net Name Baseboard Net Name Arria 10 SoC Ball Baseboard Net Name Arria 10 SoC Ball
A2 DP1_M2C_P GXBR_RX_0_P V26 GXB_RX_1_P AD26
A3 DP1_M2C_N GXBR_RX_0_N V25 GXB_RX_1_N AD25
A6 DP2_M2C_P GXBR_RX_2_P P26 GXB_RX_2_P AB26
A7 DP2_M2C_N GXBR_RX_2_N P25 GXB_RX_2_N AB25
A10 DP3_M2C_P GXBR_RX_3_P M26 GXB_RX_3_P Y26
A11 DP3_M2C_N GXBR_RX_3_N M25 GXB_RX_3_N Y25
A22 DP1_C2M_P GXBR_TX_0_P W28 GXB_TX_1_P AE28
A23 DP1_C2M_N GXBR_TX_0_N W27 GXB_TX_1_N AE27
A26 DP2_C2M_P GXBR_TX_2_P R28 GXB_TX_2_P AC28
A27 DP2_C2M_N GXBR_TX_2_N R27 GXB_TX_2_N AC27
A30 DP3_C2M_P GXBR_TX_3_P N28 GXB_TX_3_P AA28
A31 DP3_C2M_N GXBR_TX_3_N N27 GXB_TX_3_N AA27
B20 GBTCLK1_M2C_P GXBR_REFCLK1_P PLL_REFCLK_OUT_P No Connect/REFCLK_PCIE_P No Connect
B21 GBTCLK1_M2C_N GXBR_REFCLK1_N PLL_REFCLK_OUT_N No Connect/REFCLK_PCIE_N No Connect
C2 DP0_C2M_P GXBR_TX_1_P U28 GXB_TX_0_P AG28
C3 DP0_C2M_N GXBR_TX_1_N U27 GXB_TX_0_N AG27
C6 DP0_M2C_P GXBR_RX_1_P P26 GXB_RX_0_P AF26
C7 DP0_M2C_N GXBR_RX_1_N P25 GXB_RX_0_N AF25
