Building the Filesystem¶
- Building the Filesystem
Introduction¶
If you are interested in building / maintaining your own Linux distribution from source for the MitySOM-A10S family, there is a Yocto compatible meta layer for the module provided at our git-web viewer: gitweb
The current branch of the Critical Link SOCFPGA is: zeus.
The recommend Operating System for the build machine: Ubuntu 18.04
Repository¶
| Description | Repository | Branch | Web Viewer |
| Critical Link MitySOM-A10S/MitySOM-5CSx meta layer | git://support.criticallink.com/home/git/meta-cl-socfpga.git | zeus | gitweb |
Development Kit Pre-built Outputs¶
| Description | Link |
| Development Kit Filesystem Archive | mitysom-image-base-mitysom-a10s.tar.gz |
| Development Kit Filesystem SDK | poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-mitysom-a10s-toolchain-3.0.4.sh |
| Development Kit Filesystem Sources | Please contact Critical Link |
| Development Kit Filesystem Licenses | Please contact Critical Link |
Setting up the Build Environment¶
In order to build the filesystem is recommended to use Ubuntu 18.04 LTS with the following packages installed:
docker pull crops/poky:ubuntu-18.04
Setting up Yocto¶
- Open a terminal
- Clone all the needed repositories
git clone -b zeus git://git.yoctoproject.org/poky cd poky git clone -b zeus git://git.openembedded.org/meta-openembedded git clone -b zeus git://support.criticallink.com/home/git/meta-cl-socfpga.git
- Launch the docker container interactively:
docker run --rm -it -v `pwd`:/work --workdir=/work --tmpfs /opt/poky crops/poky:ubuntu-18.04 /bin/bash
- You should be inside a bash shell of the docker contain. Source the yocto environment
. ./oe-init-build-env
- Copy the Critical Link's Example configuration files into the build/conf
cp ../meta-cl-socfpga/conf/bblayers.conf.sample conf/bblayers.conf cp ../meta-cl-socfpga/conf/local.conf.a10 conf/local.conf
Performing the Yocto Build¶
The following steps will build the filesystem that is used on the Critical Link MitySOM-A10S development kit.
- Stay inside the docker container from the previous step, or if you have exited relaunch the container in the poky folder:
- Source the yocto environment
- Build the filesystem
bitbake mitysom-image-base
Outputs¶
| Description | Location |
| Filesystem Tarball | <Yocto Directory>/build/tmp/deploy/images/mitysom-a10s/mitysom-image-base-mitysom-a10s.tar.gz |
Build the SDK¶
The following steps will build the SDK with the cross-compiler toolchain that is used on the Critical Link MitySOM-A10S development kit.
Outputs¶
| Filesystem Tarball | <Yocto Directory>/build/tmp/deploy/sdk/poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-toolchain-2.4.3.sh |
Further Reading¶
