Connector Information¶
The MitySOM-AM57x modules use the connectors designed to meet the MXM specification as the physical edge connector interface. The main power (5V) input follows the MXM spec, but the rest of the pins should not be considered compatible with the MXM specification.
- The board to board mating height needs to be typically 3mm +/- 0.3mm, due to the secondary 100-pin Hirose mating height of 3.0mm.
- The MitySOM Module is compatible with either the 314 loaded contact connectors or the 310 loaded contact connectors.
- The 4 additional pins are accounted for on the module gold fingers and can be connected, or left as no-connects, on the baseboard MXM footprint. The pin connections on the module are as follows:
- E1 Pin 10 = No Connect
- E2 Pin 10 = No Connect
- E3 Pin 1 = No Connect
- E4 Pin 1 = No Connect
- Note that pins 278 and 280 on the MitySOM-AM57x modules are required to be separate pins on any connector that is used; most appear to be this way.
Critical Link has used following connectors and can provide Altium footprints upon request:¶
| Manufacturer | Part Number | Datasheet/Product Page | Note |
| JAE | MM70-314B1-2-R300 | 314 Pin Connector with 314 pins loaded | Active JAE MXM Part Number Q3 2021 (3.0mm PCB to SoM height) |
| JAE | MM70-314-310B1-2-R300 | Datasheet Drawing | NRND This is a 0.3uM gold plating thickness (3.0mm PCB to SoM height) |
| JAE | MM70-314-310B1-1-R300 | Datasheet Drawing | Obsolete This is a 0.1uM gold plating thickness (3.0mm PCB to SoM height) |
The following connectors appear to be compatible but have not been used by Critical Link and will need footprint updates/changes compared to our Dev Board.¶
Please contact your Critical Link account representative for further assistance in confirming compatibility of any connector. (info@criticallink.com)
| Aces | 91781-314xx-xx-xx | http://www.acesconn.com/series/91781-314xx-xxx/839 | 5.2mm (2.7mm PCB to SoM height) Active and Distributed by keiconn.com |
| Foxconn | AS0B826-S55B-7H | Contact Avnet | 5.5mm (2.7mm PCB to SoM height) Distributed by Avnet |
Multi-Manufacturer Compatible Footprint¶
We evaluated the creation of a single footprint that could be used for all manufacturers of MXM connectors. While possible, we would NOT recommend doing so for production boards due to manufacturability concerns.
Please note that the ACES and FOXCONN connectors are EXTREMELY similar and a single footprint may be able to be created/used for both of those, we have not done so.
