Reading Processor Temperatures¶
The AM57x has multiple temperature sensors for different parts of the processor. These can be monitored to control the CPU fan or shut down the device if temps get to dangerous levels.
Using omapconf¶
The TI-provided omapconf tool has a shortcut to view the different temperatures quickly. See the example below:
root@mitysom-am57x:~# omapconf show temp OMAPCONF (rev v1.74-1-g40ab0a2 built Fri Jan 22 21:22:26 UTC 2021) ... |--------------------------------------------| | Sensor | Temperature (C) | Temperature (F) | |--------------------------------------------| | MPU | 52 | 125 | | GPU | 53 | 127 | | CORE | 52 | 125 | | IVA | 52 | 125 | | DSPEVE | 51 | 123 | |--------------------------------------------|
Using sysfs thermal_zones¶
The kernel provides the thermal zone subsystem to auto monitor temperature sensors and can take different actions based on configurable thresholds.
The thermal zones are defined in the dra7.dtsi file and a cpu temp alert threshold has been set to 50C in am57xx-mitysom.dtsi to turn on the cpu fan output (J11)
There are 5 thermal zones, listed below:
root@mitysom-am57x:~# tail /sys/class/thermal/thermal_zone*/type ==> /sys/class/thermal/thermal_zone0/type <== cpu_thermal ==> /sys/class/thermal/thermal_zone1/type <== gpu_thermal ==> /sys/class/thermal/thermal_zone2/type <== core_thermal ==> /sys/class/thermal/thermal_zone3/type <== dspeve_thermal ==> /sys/class/thermal/thermal_zone4/type <== iva_thermal
You can get the temperatures by reading the temp file in each zone
root@mitysom-am57x:~# tail /sys/class/thermal/thermal_zone*/temp ==> /sys/class/thermal/thermal_zone0/temp <== 52600 ==> /sys/class/thermal/thermal_zone1/temp <== 52600 ==> /sys/class/thermal/thermal_zone2/temp <== 53000 ==> /sys/class/thermal/thermal_zone3/temp <== 52200 ==> /sys/class/thermal/thermal_zone4/temp <== 53800
Using standard lm-sensors¶
The lm-sensors package provides user-space support for hardware monitoring drivers. Many Linux applications use libsensors to detect and read a devices temperature sensors.
- Attached is a zip file containing the v3.6.0 lm-sensors. They can be installed using the following command:
 lmsensors_3.6.0_armv7at2hf-neon.ziproot@mitysom-am57x:~# opkg install libsensors5_3.6.0-r0_armv7at2hf-neon.ipk lmsensors-sensord_3.6.0-r0_armv7at2hf-neon.ipk lmsensors-sensors_3.6.0-r0_armv7at2hf-neon.ipk rrdtool_1.7.0-r0_armv7at2hf-neon.ipk
- The sensorscommand can then be used to show the different hardware sensors on the board.root@mitysom-am57x:~# sensors core_thermal-virtual-0 Adapter: Virtual device temp1: +46.6 C (crit = +105.0 C) cpu_thermal-virtual-0 Adapter: Virtual device temp1: +45.1 C (crit = +105.0 C) gpio_fan-isa-0000 Adapter: ISA adapter fan1: 13000 RPM (min = 0 RPM, max = 13000 RPM) dspeve_thermal-virtual-0 Adapter: Virtual device temp1: +44.2 C (crit = +105.0 C) gpu_thermal-virtual-0 Adapter: Virtual device temp1: +46.2 C (crit = +105.0 C) ltc2945-i2c-4-6e Adapter: OMAP I2C adapter in1: 5.00 V (min = +0.00 V, max = +102.38 V) (lowest = +5.00 V, highest = +5.00 V) in2: 1.01 V (min = +0.00 V, max = +2.05 V) (lowest = +1.01 V, highest = +1.01 V) power1: 39.00 W (lowest = 25.62 W, highest = 83.12 W) (max = 10.49 kW, min = 0.00 W) curr1: 9.38 A (min = +0.00 A, max = +102.38 A) (lowest = +5.12 A, highest = +16.62 A) iva_thermal-virtual-0 Adapter: Virtual device temp1: +46.6 C (crit = +105.0 C)
Note: If you only see the "ltc2945-i2c-4-6e" and "gpio_fan-isa-0000" devices.  Make sure you compile and run the latest kernel version as of 2022/11/10
A fix was applied in this commit: https://support.criticallink.com/gitweb/?p=processor-sdk-linux.git;a=commit;h=004d7911fbfb19e1503c1d249bb610410d8717cd
