On-Module Trace Lengths
NON FPGA SOM
Ethernet Trace Lengths
Ethernet traces are routed to 50ohm impedance +/- 10%
Schematic Net Class: AM57_EMAC0 (Sheet 6)
Pin Net Name Signal Length (mil)
U5 R_EMAC0_RXC 1800.279
V5 R_EMAC0_RXCTL 1838.437
W2 R_EMAC0_RXD0 1842.18
Y2 R_EMAC0_RXD1 1839.677
V3 R_EMAC0_RXD2 1843.324
V4 R_EMAC0_RXD3 1842.28
W9 R_EMAC0_TXC 1841.01
V9 R_EMAC0_TXCTL 1841.341
U6 R_EMAC0_TXD0 1850.334
V6 R_EMAC0_TXD1 1840.718
U7 R_EMAC0_TXD2 1841.371
V7 R_EMAC0_TXD3 1840.041
Schematic Net Class: AM57_TXR_EMAC0 (Sheet 6)
Pin Name Signal Length (mil)
W9 EMAC0_TXC 527.797
V9 EMAC0_TXCTL 529.032
U6 EMAC0_TXD0 529.336
V6 EMAC0_TXD1 528.254
U7 EMAC0_TXD2 519.452
V7 EMAC0_TXD3 519.535
Summed EMAC0 Values
Pin Name Signal Length (mil) Notes
W9 R_EMAC0_TXC 2418.02 Added 49.213 mils due to 22ohm 0402 series resistor
V9 R_EMAC0_TXCTL 2419.586 Added 49.213 mils due to 22ohm 0402 series resistor
U6 R_EMAC0_TXD0 2428.883 Added 49.213 mils due to 22ohm 0402 series resistor
V6 R_EMAC0_TXD1 2418.185 Added 49.213 mils due to 22ohm 0402 series resistor
U7 R_EMAC0_TXD2 2410.036 Added 49.213 mils due to 22ohm 0402 series resistor
V7 R_EMAC0_TXD3 2408.789 Added 49.213 mils due to 22ohm 0402 series resistor
Schematic Net Class: AM57_EMAC1 (Sheet 6)
C5 R_EMAC1_RXC 1197.729
A3 R_EMAC1_RXCTL 1187.946
A4 R_EMAC1_RXD0 1205.63
B5 R_EMAC1_RXD1 1190.511
B4 R_EMAC1_RXD2 1202.505
B3 R_EMAC1_RXD3 1187.73
D5 R_EMAC1_TXC 862.338
C2 R_EMAC1_TXCTL 859.368
D6 R_EMAC1_TXD0 861.764
B2 R_EMAC1_TXD1 861.205
C4 R_EMAC1_TXD2 864.462
C3 R_EMAC1_TXD3 863.562
Schematic Net Class: AM57_TXR_EMAC1 (Sheet 6)
D5 EMAC1_TXC 358.118
C2 EMAC1_TXCTL 356.218
D6 EMAC1_TXD0 357.445
B2 EMAC1_TXD1 354.552
C4 EMAC1_TXD2 355.112
C3 EMAC1_TXD3 355.271
Summed EMAC1 Values
D5 R_EMAC1_TXC 1269.669 Added 49.213 mils due to 22ohm 0402 series resistor
C2 R_EMAC1_TXCTL 1264.799 Added 49.213 mils due to 22ohm 0402 series resistor
D6 R_EMAC1_TXD0 1268.422 Added 49.213 mils due to 22ohm 0402 series resistor
B2 R_EMAC1_TXD1 1264.97 Added 49.213 mils due to 22ohm 0402 series resistor
C4 R_EMAC1_TXD2 1268.787 Added 49.213 mils due to 22ohm 0402 series resistor
C3 R_EMAC1_TXD3 1268.046 Added 49.213 mils due to 22ohm 0402 series resistor
WITH FPGA SOM
Y2 R_EMAC0_RXD1 1839.272
V3 R_EMAC0_RXD2 1843.051
Summed EMAC0 Values
V7 R_EMAC0_TXD3 2408.788 Added 49.213 mils due to 22ohm 0402 series resistor
B5 R_EMAC1_RXD1 1191.106
Summed EMAC1 Values
