The Core Version Register is common FPGA VHDL code that is used in all "standard" FPGA Cores for the MitySOM-AM57x framework.
The Core Version Register is generally located at the 0x00 (first) offset in a core address space. It is a 16-bit wide register that behaves like a circular FIFO or ring buffer. 4 reads of the register are required to access the complete contents of the register data. The table below lists the fields and the read cycle. The top 2 bits can be used to decode which read cycle contents are presented.
Read Cycle D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0
0 00 LVL VEC ID
1 01 YEAR VER_MAJ VER_MIN
2 10 00 MONTH 000 DAY
3 11 0000000000 NUM_VEC
Field Descriptions
Field Description
ID an 8 bit core ID
VEC the interrupt vector level (if used)
LVL the interrupt level. 0 is for SYS_NIRQ1, 1 is for SYS_NIRQ2.
VER_MAJ the Core major version number
VER_MIN the Core minor version number
YEAR the year, since 2000, of the last modification date of the core
MONTH the month (1-12), of the last modification date of the core
DAY the day (1-31), of the last modification date of the core
NUM_VEC Number of vectors minus 1 so 0=1 vector, 1=2 vectors,... 0xF=0 vectors
If multiple vectors are used, they are sequential where VEC specifies the lowest numbered vector.
Known FPGA IDs
This is a list of known FPGA IDs in the common / distributed IP cores. Users may define their own IDs for application specific projects.
ID (dec) Description
4 GPIO Core
11 ADS8343 4-channel ADC interface Core
16 ADS8344 8-channel ADC interface Core
45 ADS1274 Interface Core
64 Stream to PCIe DMA Core
69 PCIe DMA Control Core
71 Video Test Pattern Generator Core
