Docker build environment¶
https://docs.docker.com/get-started/overview/
Docker images are used to provide a consistent/known environment of which we can run our builds.
These instructions assume you are running Ubuntu Linux 18.04+ 64-bit
Note: Running these steps using a VM or Windows Subsystem for Linux may work but might result in some disk performance issues
Docker engine¶
- Install docker engine: https://docs.docker.com/engine/install/ubuntu/
$ sudo apt-get remove docker docker-engine docker.io containerd runc $ sudo apt-get update $ sudo apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common $ curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add - $ sudo add-apt-repository \ "deb [arch=amd64] https://download.docker.com/linux/ubuntu \ $(lsb_release -cs) \ stable" $ sudo apt-get update $ sudo apt-get install docker-ce docker-ce-cli containerd.io $ sudo docker run hello-world
- Note: If you are running in a proxy environment, these commands will not work as-is. You will need to configure docker and possibly your OS to use your network proxy. Please confirm your version of Docker and then follow https://docs.docker.com/network/proxy/ for more information.
- Allow your user to run docker commands https://docs.docker.com/engine/install/linux-postinstall/
Warning: The docker group grants privileges equivalent to the root user$ sudo usermod -aG docker $USER $ sudo chown "$USER":"$USER" /home/"$USER"/.docker -R $ sudo chmod g+rwx "$HOME/.docker" -R $ newgrp docker $ docker run hello-world $ sudo systemctl enable docker
U-boot/Kernel/Yocto¶
The crops/poky:ubuntu-18.04 image is setup with all the packages to build Yocto images and we can also use it to build U-boot and the Kernel.
Setup¶
- Download a prebuilt toolchain from ARM and extract it to /home/tools (You can put it wherever you like, you'll just need to update the instructions accordingly)
$ mkdir -p /home/tools/mitysom-57x/ $ wget https://developer.arm.com/-/media/Files/downloads/gnu-a/8.3-2019.03/binrel/ gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf.tar.xz -O - | tar -Jxv -C /home/tools/mitysom-57x/
- Pull crops/poky image and echo test
docker pull crops/poky:ubuntu-18.04 docker run --rm crops/poky:ubuntu-18.04 echo Test
Usage¶
If we mount our local directory into the docker container we can enter the docker container and run our builds.- cd to your work directory
- Launch poky image
$ docker run --rm -it -v $PWD:/work -v /home/tools:/home/tools --env "TOOLCHAIN_PATH_ARMV7=/home/tools/mitysom-57x/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf" crops/poky:ubuntu-18.04 --workdir=/work pokyuser@e34e187356b3:/workdir$ id uid=9338(pokyuser) gid=502(pokyuser) groups=502(pokyuser)
Explanation:
docker run Run a command in a new container
--rm Automatically remove the container when it exits
-it Allows interracting with container over STDIN
-v $PWD:/work Mounts current directory to /workdir inside container
-v /home/tools:/home/tools Mount tools directory so we can access downloaded toolchain
--env "TOOLCHAIN_PATH_ARMV7=/home/tools/mitysom-57x/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf" Set environment variable needed for processor-sdk Yocto build
crops/poky:ubuntu-18.04 Selects docker image to run
--workdir=/work Tells crops poky-entry.py script to create a user pokyuser with a matching user id and group id of the owner of /work
Alternatively, we can run a command directly (echo Test) and the docker container will exit when the command finishes.
$ docker run --rm -it -v $PWD:/work -v /home/tools:/home/tools --env "TOOLCHAIN_PATH_ARMV7=/home/tools/mitysom-57x/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf" crops/poky:ubuntu-18.04 --workdir=/work echo Test Test
All of this can be wrapped into a bash script so we don't forget. docker-poky.sh
Using your Docker image for Yocto Development¶
There are many ways to use your Docker image for development depending on your needs. Once you have completed the Docker setup previously described, you can use the Yocto project to build your own kernel, U-Boot, and filesystem.
Critical Link uses TI's Yocto infrastructure to generate the MitySOM-AM57x binaries listed under the Files tab.
These instructions will show you how to create a Yocto build structure interactively. Once you are comfortable with the setup, you can script it using a build server (e.g. Jenkins) for repeatable builds.
First, create a development directory and start your docker image and run a shell:
$ mkdir devel $ cd devel $ docker run --rm -it -v $PWD:/work -v /home/tools:/home/tools --env "TOOLCHAIN_PATH_ARMV7=/home/tools/mitysom-57x/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf" crops/poky:ubuntu-18.04 --workdir=/work
This will give you a shell prompt inside the docker image. Go to the /work
directory (actually the devel
directory outside of the docker image) and run the following commands:
Starting with UID : 9337 user@8ec23474095b:~$ cd /work user@8ec23474095b:~$ git clone --single-branch --branch criticallink https://support.criticallink.com/git/oe-layersetup.git user@8ec23474095b:~$ cd oe-layersetup user@8ec23474095b:~$ ./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-06.03.00.106-cl-external-config.txt
This will download many Yocto repositories, including Critical Link's
meta-mitysom
Now, enter the build directory and configure your local.conf
. These additions to the local.conf
are optional but recommended. The rm_work
option helps reduce disk usage and the archiver options are used to save the source code used for your builds. Finally the source
command sets up your build environment.
user@8ec23474095b:~$ cd build user@8ec23474095b:~$ source conf/setenv user@8ec23474095b:~$ echo 'INHERIT += "rm_work" ' >> conf/local.conf user@8ec23474095b:~$ echo 'INHERIT += "archiver"' >> conf/local.conf user@8ec23474095b:~$ echo 'ARCHIVER_MODE[src] = "original"' >> conf/local.conf
At this point, your Yocto build environment is configured and you can bring your build. As a starting point, you could build a filesystem, kernel, and U-Boot compatible with our MitySOM-AM57x Dev Board by running:
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake arago-base-tisdk-image
You can also build a full SDK using:
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake arago-core-tisdk-bundle
Or a TBD using:
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake meta-toolchain-arago-tisdk
A Note about Yocto Errors¶
A full Yocto build will stress your CPU, RAM, and disk space. This can sometimes cause errors that are difficult to troubleshoot.
If you get a error in a recipe that you did not modify, and you are certain there is not a RAM or disk space problem, you can usually clear the offending error by building the package independently.
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake arago-base-tisdk-image ... <Various status and output from each recipe> ... NOTE: recipe vlib-c66x-3_2_1_0-r0: task do_populate_lic: Started WARNING: vlib-c66x-3_2_1_0-r0 do_populate_lic: Could not copy license file /work/build/arago-tmp-external-arm-toolchain/work/armv7at2hf-neon-linux-gnueabi/vlib-c66x/3_2_1_0-r0/vlib_c66x_3_2_1_0/docs/VLIB_Software_Manifest.html to /work/build/arago-tmp-external-arm-toolchain/work/armv7at2hf-neon-linux-gnueabi/vlib-c66x/3_2_1_0-r0/license-destdir/vlib-c66x/VLIB_Software_Manifest.html: [Errno 2] No such file or directory: '/work/build/arago-tmp-external-arm-toolchain/work/armv7at2hf-neon-linux-gnueabi/vlib-c66x/3_2_1_0-r0/vlib_c66x_3_2_1_0/docs/VLIB_Software_Manifest.html' ERROR: vlib-c66x-3_2_1_0-r0 do_populate_lic: QA Issue: vlib-c66x: LIC_FILES_CHKSUM points to an invalid file: /work/build/arago-tmp-external-arm-toolchain/work/armv7at2hf-neon-linux-gnueabi/vlib-c66x/3_2_1_0-r0/vlib_c66x_3_2_1_0/docs/VLIB_Software_Manifest.html [license-checksum] ERROR: vlib-c66x-3_2_1_0-r0 do_populate_lic: Fatal QA errors found, failing task. ERROR: vlib-c66x-3_2_1_0-r0 do_populate_lic: Function failed: populate_lic_qa_checksum ERROR: Logfile of failure stored in: /work/build/arago-tmp-external-arm-toolchain/work/armv7at2hf-neon-linux-gnueabi/vlib-c66x/3_2_1_0-r0/temp/log.do_populate_lic.32041 NOTE: recipe vlib-c66x-3_2_1_0-r0: task do_populate_lic: Failed ERROR: Task (/work/sources/meta-ti/recipes-ti/vlib/vlib-c66x_3.2.1.0.bb:do_populate_lic) failed with exit code '1'
In this case, the build was stopped due to an error in the vlib-c66x-3_2_1_0-r0. The error is complaining that it can't find "
." Instead of just restarting the build, you can run the following commands to reset the vlib-c66x
recipe and build it independently:
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake -c clean vlib-c66x user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake vlib-c66x
If that succeeds, the result will be cached and you can re-run your previous bitbake command (e.g. MACHINE=mitysom-am57x bitbake arago-base-tisdk-image
Yocto Linux Kernel Build¶
You can change the configuration of the kernel by running:
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake -c menuconfig virtual/kernel
Then, to build the kernel:
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake virtual/kernel
Yocto U-Boot Build¶
user@8ec23474095b:~$ MACHINE=mitysom-am57x bitbake virtual/bootloader
Linux applications¶
TODO
FPGA software¶
TODO
DSP software¶
TODO
