AM62a/p R5F RPMsg echo to ArmLinux
Objectives:
  • Build and run an R5F program which will echo any RPMsg message it receives back to the sender.
  • Build and run an ARM/Linux user program which will send a number of messages to the M4 and receive the messages echoed back.
  • Run both of these programs in debuggers.
References
  • Code Composer installed
  • R5F sdk installed
  • ti-processor-sdk installed (TI_SDK_download_and_installation)
  • Create a project directory on your device
    root@mitysom-am62px:~# mkdir /lib/firmware/mcu_rpmsg
Step 1: Building the R5F program
  • Navigate to toolbar>View>Project Explorer
    • In the project explorer window go to import projects.
      • Hit the drop down arrow for the "Code Composer Studio" Folder and click "CCS Projects"
        • Click the browse button and open the following folder <MCU_PLUS_SDK_INSTALL_DIR>/ti/mcu_plus_sdk_{am62a/p}_10_01_00_33/examples/drivers/ipc/ipc_rpmsg_echo_linux/{am62ax/px}-sk/mcu-r5fss0-0_freertos/ti-arm-clang
        • Right Click the opened project and select "Build Project"
  • Create new target configuration at toolbar>View>Target Configuration.
    • Right Click on "User Defined" and select "New Target Configuration"
      • Name the file {som name}_XDS2XX.ccxml.
        • Under the "General Setup" section, next to "Connection" open the drop-down arrow and select "Texas Instruments XDS2xx USB Debug Probe"
        • Under the "General Setup" section, next to "Board or Device" scroll and select AM62P or AM62A.
        • Click the "Save" button under the "Save Configuration" section.
    • Right click on target configuration you just made and select "Launch Selected Configuration"
  • In the debug window right click on "Texas Instruments XDS2xx USB Debug Probe_0/MCU_R5FSS0_0(Disconnected:Unkown) and select "Connect Target"
    • In the debug toolbar navigate to the CPU reset drop-down arrow and select CPU Reset
      • Navigate to toolbar>Run>Load>Load Program and select "Browse project..."
        • Select the following file ipc_rpmsg_echo_linux_{am62ax/px}-sk_mcu-r5fss0-0_freetos_ti-arm-clang/debug/ipc_rpmsg_echo_linux_{am62ax/px}-sk_mcu-r5fss0-0_freetos_ti-arm-clang.out
        • The program is now paused and must be resumed. Go to toolbar>Run>Resume
        • You should now see the following output to the CCS and MCU Console
CCS Console
{som name}_XDS2XX.ccxml:CIO
[MCU_R5FSS0_0] [IPC RPMSG ECHO] Version: REL.MCUSDK.K3.10.01.00.33+ (Feb 13 2025 14:59:21):
MCU Console
[IPC RPMSG ECHO] Version: REL.MCUSDK.K3.10.01.00.10+ (Nov 14 2024 14:00:57):
[IPC RPMSG ECHO] Remote Core waiting for messages at end point 13 ... !!!
[IPC RPMSG ECHO] Remote Core waiting for messages at end point 14 ... !!!
Step 2: Use remoteproc to start the program on the target
  • Copy the debug version to the mcu_rpmsg folder
    $ cd <WORKSPACE_DIR>/ipc_rpmsg_echo_linux_{am62ax/px}-sk_mcu-r5fss0-0_freertos_ti-arm-clang/Debug
    $ scp ipc_rpmsg_echo_linux.mcu-r5f0_0.strip.out root@<IP_ADDRESS>:/lib/firmware/mcu_rpmsg
  • link /lib/firmware/{am62a/p}-mcu-r5f0_0-fw to the release version
    root@mitysom-am62px:~# ln -sf /lib/firmware/mcu_rpmsg/ipc_rpmsg_echo_linux.mcu-r5f0_0.strip.out /lib/firmware/{am62a/p}-mcu-r5f0_0-fw
  • Toggle the m4 remote processor
    root@mitysom-am62px:~# echo stop >/sys/class/remoteproc/remoteproc0/state
    [  250.317807] remoteproc remoteproc0: stopped remote processor 79000000.r5f
    root@mitysom-am62px:~# echo start >/sys/class/remoteproc/remoteproc0/state
    [  255.786040] remoteproc remoteproc0: powering up 79000000.r5f
    [  255.792268] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 141000
    [  255.801793] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [  255.813995] virtio_rpmsg_bus virtio0: rpmsg host is online
    [  255.814592] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [  255.819731] rproc-virtio rproc-virtio.4.auto: registered virtio0 (type 7)
    [  255.827488] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [  255.834007] remoteproc remoteproc0: remote processor 79000000.r5f is now up
  • On the R5 UART, you should see output like:
At this point, the R5 program is running and waiting for the Arm/Linux to send it messages.
Step 3: Building the Arm/Linux user program
  • Download the example TI git repository.
    $ mkdir rpmsg
    $ cd rpmsg
    $ git clone https://git.ti.com/cgit/rpmsg/ti-rpmsg-char
  • Setup the ARM Toolchain
  • Download the necessary infrastructure tools
    $ sudo apt install autotools-dev autoconf automake libtool
  • Build the example
    $ cd ti-rpmsg-char
    $ autoreconf -i
    #ignore all warnings
    $ mkdir outputs
    $ ./configure --host=aarch64-none-linux-gnu --prefix=$PWD/outputs/
    $ make
    $ make install
    $ make -C examples
    $ make -C examples install
    $ scp examples/rpmsg_char_simple root@<IP_ADDRESS>:/lib/firmware/mcu_rpmsg
  • Boot remote core from linux kernel
    root@mitysom-am62px:~# cd /lib/firmware/mcu_rpmsg
    root@mitysom-am62px:~/lib/firmware/mcu_rpmsg# echo stop > /sys/class/remoteproc/remoteproc0/state
    root@mitysom-am62px:~/lib/firmware/mcu_rpmsg# echo start > /sys/class/remoteproc/remoteproc0/state
  • Check that the /lib/firmware has the proper symbolic link
    root@mitysom-am62px:~/lib/firmware/mcu_rpmsg# ls -l /lib/firmware/
    total 25308
    -rw-r--r-- 1 root root    2040 Mar  9  2018 LICENCE.ibt_firmware
    -rw-r--r-- 1 root root    2046 Mar  9  2018 LICENCE.iwlwifi_firmware
    lrwxrwxrwx 1 root root      65 Feb 17 16:16 am62p-mcu-r5f0_0-fw -> /lib/firmware/mcu_rpmsg/ipc_rpmsg_echo_linux.mcu-r5f0_0.strip.out
    lrwxrwxrwx 1 root root      80 Mar  9  2018 am62p-mcu-r5f0_0-fw-sec -> /usr/lib/firmware/ti-ipc/am62pxx/ipc_echo_test_mcu2_0_release_strip.xer5f.signed
  • Run the example program
    root@mitysom-am62px:~/lib/firmware/mcu_rpmsg# rpmsg_char_simple -r 0 -n 9
    Created endpt device rpmsg-char-0-2589, fd = 4 port = 1025
    Exchanging 9 messages with rpmsg device rpmsg-char-0-2589 on rproc id 0 ...
    Sending message #0: hello there 0!
    Received message #0: round trip delay(usecs) = 220499
    hello there 0!
    Sending message #1: hello there 1!
    Received message #1: round trip delay(usecs) = 64511
    hello there 1!
    Sending message #2: hello there 2!
    Received message #2: round trip delay(usecs) = 45786
    hello there 2!
    Sending message #3: hello there 3!
    Received message #3: round trip delay(usecs) = 46716
    hello there 3!
    Sending message #4: hello there 4!
    Received message #4: round trip delay(usecs) = 46186
    hello there 4!
    Sending message #5: hello there 5!
    Received message #5: round trip delay(usecs) = 46471
    hello there 5!
    Sending message #6: hello there 6!
    Received message #6: round trip delay(usecs) = 43971
    hello there 6!
    Sending message #7: hello there 7!
    Received message #7: round trip delay(usecs) = 43971
    hello there 7!
    Sending message #8: hello there 8!
    Received message #8: round trip delay(usecs) = 47246
    hello there 8!
    Communicated 9 messages successfully on rpmsg-char-0-2589
    TEST STATUS: PASSED
Note: If running the example program fails try stopping and starting the remoteproc again.
Running in Debugger
  • Open ipc_rpmsg_echo.c
  • In the function ipc_rpmsg_echo_main(), change the initial code to look like:
Initial Code
void ipc_rpmsg_echo_main(void *args)
    int32_t status;
    DebugP_log("[IPC RPMSG ECHO] Version: %s (%s %s):  \r\n", IPC_FW_VERSION, __DATE__, __TIME__);
Modified Code
    int32_t status;
    int max_wait_time = 180;
    DebugP_log("Starting to wait for debugger attach. %d seconds\r\n", max_wait_time);
    for (int ii = 0; ii < max_wait_time; ++ii)
        if ((ii % 5) == 0)
            DebugP_log("%3d secs: Waiting for debugger attach\r\n", ii);
        ClockP_sleep(1);
    DebugP_log("Done waiting for debugger attach. Moving on...\r\n");
  • Rerun through "Step 2: Use remoteproc to start the program on the target" to copy the debug release and link it to your remote processor
    • Your output should look like the following:
      [IPC RPMSG ECHO] Version: REL.MCUSDK.K3.10.01.00.33+ (Feb 17 2025 13:48:55):
      Starting to wait for debugger attach. 180 seconds
        0 secs: Waiting for debugger attach
        175 secs: Waiting for debugger attach
  • Rerun through "Step 1: Building the M4 program" to run the program via Jtag.
  • In ipc_rpmsg_echo_main() put a breakpoint on the line ClockP_sleep(1):
    • Resuming the target 5 times will show the new time in seconds that the program has been waiting for the debugger to attach in the mcu uart terminal
Summary
This page demonstrates how to
  • Build and run an R5F program in CCS, which will echo any RPMsg message it receives back to the sender.
