Getting Started
This page provides links to information about getting start using the MitySOM-AM62 or MitySOM-AM62A and Development kit.
Unless specifically noted, the examples below should apply to both the MitySOM-AM62 or the MitySOM-AM62A.
Initial Hands-on Examples
Serial Console This example connects the Development Kit Console port to a host system, powers up the development kit, and provides basic verification that the development kit is working.
Hello World This example creates and runs a simple Hello World program on the ARM processor of the development kit.
1 Gb Ethernet This example connects and verifies the basic operation of the 1 Gb Ethernet link.
Reading Temperature and Power Monitors This example demonstrates how to read the CPU temperature and SOM power monitor.
Setting SOM Clock Speed This example demonstrates how to read and control the SOM Cortex A-53 Clock speeds in linux.
Leds This example demonstrates how to control the different LEDs in linux.
Cortex-A53 Peripherals
USB A ports This example demonstrates the use of the USB 2.0 Host ports with the Development Kit.
HDMI This example demonstrates the use of an hdmi display with the Development Kit.
Audio This example demonstrates the use of the audio in and audio out ports
SOM OSPI NOR This example provides information on how to use the SOM OSPI NOR on the Development Kit.
SOM eMMC This example provides information on how to use the SOM eMMC on the Development Kit.
RNDIS setup This example provides information on how to setup RNDIS on the Development Kit Dual Role Port.
Accessing a GPIO pin This example provides information on how to access a GPIO pin from the command line.
USB 2 Dual Role How to use the USB 2.0 dual role port in both roles
CSI2 Camera Capture Example to capture from MIPI/CSI-2 camera module
TI WL1837 WIFI/BT Module How to use Wifi/BT with the WL1837 module
MCU CAN Access from Cortex A-53
Accessing MCU CAN ports from Cortex A-53 Information to use MCU MCAN ports on DevKit with A-53 core
Edge AI Examples (MitySOM-AM62A Only)
AM62Ax Edge AI Examples Information on running the TI supplied Edge AI Demos
MCUSS Peripherals (MitySOM-AM62 Only)
MCU CAN Interfaces Information and examples on using the MCU MCAN interface from the M4
PRUSS Peripherals (MitySOM-AM62 Only)
Startup Related
boot options How to configure different boot modes for the module
