AM62 MCAN Interface¶
The AM62 devkit supports 2 CAN interfaces, controlled by the M4 processor (MCUSS). These interfaces are available on the devkit via J11 (MCAN0) and J12 (MCAN1) [ pins 256/258 MCU_MCAN0_TX/RX pins 252/254 MCU_MCAN1_TX/RX ].
Objective¶
This example demonstrates a simple loopback between the 2 CAN interfaces from the MCU processor. It is heavily based on the TI example project, which was a single interface loopback.
Prerequisites¶
To run this example, you will need to have installed Code Composer and the TI SDK as shown in the M4FMCU_Development page
Steps¶
- Connect the 2 CAN interfaces together as shown here
 - Install one of the termination jumpers (J17/J18)
Example project¶
- This project is available on the Critical Link Git repository (https://support.criticallink.com/gitweb/?p=mcan_loopback_polling_am62x-sk_m4fss0-0_freertos_ti-arm-clang.git;a=summary)
 - Clone the repository and then import the project into code Composer Studio
- From the Project menu, select Import CCS Projects...
 - With Select search-directory selected, Click the "Browse..." button and Select the working directory you cloned
 - Make sure the mcan_loopback project is selected and click "Finish"
 - The project includes a target configuration suitable for JTAG connection via an XDS200 emulator pod.
 - Build the project
The output file will located at Debug/mcan_loopback_polling_am62x-sk_m4fss0-0_freertos_ti-arm-clang.out
Note: Ignore all errors and warnings
Load the program¶
The loopback program can be loaded using JTAG or Remoteproc:
JTAG¶
- Launch Am62x Target configuration
- Open Target Configurations View
 - Expand the Projects, expand macn_loopback..., expand targetConfigs
 - Double click on AM62.ccxml to change/test the connection if necessary
 - Select AM62.ccxml, right-mouse->Launch Selected Configuration
 - Connect to target.
- Select BLAZER_Cortex_M4F_1, right-mouse->Connect Target
 - Reset CPU.
- Menu Bar->Run->Reset->CPU Reset
 - Load program.
- Menu Bar->Run->Load->Load Program.
 - Browse Project. Pick debug executable (mcan_loopback....arm_clang.out)
- Press OK
 - Press OK
 - If the program does not start running, you may have to select continue.
 - Output will appear in Code Composer and on the M4 uart.
Remoteproc¶
- Apply patches to the imported project
- With the patches, the program can be loaded through the remoteproc process, but not through JTAG.
 - See m4_hello_world_patches_for_use_with_remoteproc
 - Build release version
 - Copy release version to /lib/firmware/loopback_polling/am62-mcu-m4f0_0-fw
ssh target_62x mkdir -p /lib/firmware/loopback_polling scp Release/mcan_loopback_polling_am62x-sk_m4fss0-0_freertos_ti-arm-clang.out target_62x:/lib/firmware/loopback_polling
- Link /lib/firmware/am62-mcu-m4f0_0-fw to loopback_polling
ssh target_62x ln -sf /lib/firmware/loopback_polling/mcan_loopback_polling_am62x-sk_m4fss0-0_freertos_ti-arm-clang.out /lib/firmware/am62-mcu-m4f0_0-fw
- On the target
- See the different remote processors
cd /sys/class/remoteproc tail */name
- Pick out the one for the mcu (e.g. remoteproc0) and see the current state of the processor.
tail *0/state
- Stop the processor
echo 'stop' > *0/state
- Start the processor (will load the new program)
echo 'start' > *0/state
- Output will appear on the M4 uart.
Conclusion¶
This example sets the stage for using the MCAN interfaces from the MCU. The M4 image can be loaded and run from Linux on the A53 processor using the remoteproc Framework.
Inter-processor communication is then supported via Linux rpmsg device (TI has written one for their processor families)
