Booting from OSPI¶
- Booting from OSPI
NOTE: Booting from OSPI is a different mode than QSPI
To boot the Dev Kit from OSPI using a CL supplied image, set the boot pins as follows:
B9 | B8 | B7 | B6 | B5 | B4 | B3 |
Reserved (0) | lclk (1) | Csel (0) | 0 | 0 | 0 | 1 |
Steps¶
- boot to linux (i.e. from SD card).
- cd to boot partition (the directory containing tibot3.bin, etc.../run/media/mmcblk1p1 in my case.)
- copy the boot files to their respective locations in SPI NOR
root@mitysom-am62x:~# cp tiboot3.bin /dev/mtd0 root@mitysom-am62x:~# cp tispl.bin /dev/mtd1 root@mitysom-am62x:~# cp u-boot.img /dev/mtd2 root@mitysom-am62x:~# dd if=/dev/mmcblk0boot0 bs=512 skip=13312 count=256 of=uboot.env root@mitysom-am62x:~# cp uboot.env /dev/mtd3 0x0 +----------------------------+ | ospi.tiboot3(512k) | | | 0x80000 +----------------------------+ | ospi.tispl(2m) | | | 0x280000 +----------------------------+ | ospi.u-boot(4m) | | | 0x680000 +----------------------------+ | ospi.env(128k) | | | 0x6c0000 +----------------------------+ | ospi.env.backup(128k) | | | 0x740000 +----------------------------+ | padding (768k) | 0x800000 +----------------------------+ | ospi.rootfs(ubifs) | | | 0xffc0000 +----------------------------+ | ospi.phypattern (256k) | | | +----------------------------+
