Yocto AM62Ax SDK 10 Release Notes
  • 10.01.00.05 - 20250430 Release Notes
    Same: TI SDK 10.01.00.05 - https://software-dl.ti.com/processor-sdk-linux/esd/AM62AX/10_01_00/exports/docs/devices/AM62AX/linux/Release_Specific_Release_Notes.html
    Same: Linux Kernel 6.6.58
    Same: U-Boot 2024.04
    Same: TI Processor Firmware v10.01.08 (Fiery Fox)
    Note: Kernel: 1.4 Ghz support has been disabled due to Errata: 4.7
    Fixed/Hack: U-boot: Disable UHS sdcard in u-boot to prevent certain cards from breaking boot
    Fixed: Kernel: Reduce thermal shutdown temp to 100C to account for cpu temp sensor accuracy and for processor extended temp range
    Update: U-boot: Add fastboot environment variables
    Known Issue: Booting from SPI NOR does not work
    Known Issue: U-Boot: Ethernet port 2 does not work (only in U-Boot)
  • 10.01.00.05 - 20250220 Release Notes
    Removed links - sdcard had incorrect TI processor firmware
    Update: TI SDK 10.01.00.05 - https://software-dl.ti.com/processor-sdk-linux/esd/AM62AX/10_01_00/exports/docs/devices/AM62AX/linux/Release_Specific_Release_Notes.html
    Update: Linux Kernel 6.6.58
    Update: U-Boot 2024.04
    Update: TI Processor Firmware v10.01.08 (Fiery Fox)
    Fixed: Possibility of video not working on boot
    Fixed: Set RTC 32Khz clock. System time was drifting slightly
    Fixed: Occasional "Internal error: Oops" related to dsp rproc
    Fixed: Occasional "Internal error: Oops" related to omap-dmtimer-pwm
    Fixed: Overlay loading in u-boot
    Fixed: U-boot: Update to DDR Config Tool v0.10.02 -- Fix for rare kernel boot crash
    Fixed: U-boot: Fix early u-boot crash during CA VREF training
    Fixed: Kernel: Fix rare boot crash in led_pwm_probe
    Note: Removed bmap from sdcard image to avoid balenaEtcher bug
  • 10.00.00 - 20250207 Release Notes
    Update: TI SDK 10.00.00 - https://downloads.ti.com/processor-sdk-linux/esd/AM62AX/10_00_00/exports/docs/devices/AM62AX/linux/Release_Specific_Release_Notes.html
    Update: Linux Kernel 6.6.32
    Update: TI Processor Firmware v10.00.08 (Fiery Fox)
    Fixed: U-boot: Possibility of video not working on boot
    Fixed: U-boot: Overlay loading in u-boot
    Known Issue: U-Boot: Ethernet port 2 does not work (in U-Boot)
  • 10.00.00 - 20241101 Release Notes
    Update: TI Processor Firmware v10.00.08 (Fiery Fox) TI Indicates this update is critical
    Enhancement: U-Boot: Will now search for overlays in both “/boot/dtb” and “/boot/dtb/ti”
    Note: Kernel: 1.4 Ghz support has been disabled due to Errata: 4.3
    Fixed: Kernel: Capturing from a MIPI camera will no longer cause a rare kernel panic
    Fixed: Kernel: MMC tuning errors have been greatly reduced and will be handled if they occur
    Known Issue: Occasional "Internal error: Oops" related to dsp rproc
    Known Issue: Occasional "Internal error: Oops" related to omap-dmtimer-pwm
Note: An early 10.00.00 - 20240710 version was released, this was rereleased as the kernel hash didn't match the rebased commits pushed to support.criticallink.com and was missing the Errata 4.3 fix
