Updating the TI EVM Debian Image for the MitySOM-AM62x DevKit¶
These instructions are what was done to update a TI supplied Debian micro-SD card image for the AM62x EVM to support / work with the MitySOM-AM62x Development Kit. These instructions were performed on a Ubuntu Linux host and require sudo privileges.
Please use the correct images for this procedure. The SDK version of the TI image and the Critical Link version should match. If you are targeting the AM62P, make sure you use the am62pxx images. If you are targeting the am62x, make sure you are using the am62x images.
NOTE: Detailed testing of all of the peripherals on the Debian image has not been performed. Console, display, and ethernet has been validated.
- fetch both the TI debian image and the Critical Link image from the same SDk release. In this example SDk 10 was used, and the files downloaded were "tisdk-debian-trixie-am62xx-evm.wic.xz" from TI and "tisdk-default-image-mitysom-am62x.rootfs-SDK10.01.10_28-20250220175550.img.zip" from Critical Link.
- Uncompress the files (assumed in /tmp)
user:/tmp # xz -d tisdk-debian-trixie-am62xx-evm.wic.xz user:/tmp # unzip tisdk-default-image-mitysom-am62x.rootfs-SDK10.01.10_28-20250220175550.img.zip
- create a loopback device for the Debian Image and mount both the partitions. Note: the losetup command will likely report a different loopback device number. Make sure you update your commands to use the correct loopdevice /dev/loopXX reported by the first command!
user:/tmp # sudo losetup --find --show --partscan tisdk-debian-trixie-am62xx-evm.wic /dev/loop20 user:/tmp # mkdir /tmp/debianp1 user:/tmp # sudo mount /dev/loop20p1 /tmp/debianp1 user:/tmp # mkdir /tmp/debianp2 user:/tmp # sudo mount /dev/loop20p2 /tmp/debianp2
- Repeat the same procedure for the CL provided Yocto Image:
user:/tmp # sudo losetup --find --show --partscan tisdk-default-image-mitysom-am62x.rootfs-20250220175550.img /dev/loop50 user:/tmp # mkdir /tmp/clp1 user:/tmp # sudo mount /dev/loop50p1 /tmp/clp1 user:/tmp # mkdir /tmp/clp2 user:/tmp # sudo mount /dev/loop50p2 /tmp/clp2
- Copy the boot images over to the debian boot partition
user:/tmp # cd /tmp/debianp1 user:/tmp # sudo mkdir old && mv * old user:/tmp # sudo cp -Rap /tmp/clp1/* .
- Copy over the kernel, device tree files, and kernel modules to the debian root partition
user:/tmp # cd /tmp/debianp2/boot user:/tmp # sudo mv Image Image.old user:/tmp # sudo cp -Rap /tmp/clp2/boot/Image* . user:/tmp # cd /tmp/debianp2/boot/dtb/ti user:/tmp # sudo cp -Rap /tmp/clp2/boot/dtb/ti/* . user:/tmp # cd /tmp/debianp2/lib/modules user:/tmp # sudo cp -Rap /tmp/clp2/lib/modules/* .
- unmount the filesystems and close down the loop device
user:/tmp # cd /tmp user:/tmp # sudo umount /tmp/clp1 user:/tmp # sudo umount /tmp/clp2 user:/tmp # sudo umount /tmp/debianp1 user:/tmp # sudo umount /tmp/debianp2 user:/tmp # sudo losetup -d /dev/loop20 user:/tmp # sudo losetup -d /dev/loop50
- at this point the tisdk-debian-trixie-am62xx-evm.wic image should now be ready to flash to an SD card and run on the MitySOM-AM62x DevKit.
