Yocto AM62x SDK 10 Release Notes¶
- 10.01.10.04 - 20250430 Release Notes
Same: TI SDK 10.01.10.04 - https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/10_01_10_04/exports/docs/devices/AM62X/linux/Release_Specific_Release_Notes.html
Same: Linux Kernel 6.6.58
Same: U-Boot 2024.04
Same: TI Processor Firmware v10.01.08 (Fiery Fox)
Note: Kernel: 1.4 Ghz support has been disabled for SOMs older than Rev5 due to Errata: 4.7
Fixed: U-boot: Update ddr4 timings to support up to 95C. See https://support.criticallink.com/redmine/projects/mitysom_am62x/wiki/Memory_Bandwidth
Fixed/Hack: U-boot: Disable UHS sdcard in u-boot to prevent certain cards from breaking boot
Fixed: Kernel: Reduce thermal shutdown temp to 100C to account for cpu temp sensor accuracy
Update: U-boot: Add fastboot environment variables
Known Issue: Booting from SPI NOR does not work
- 10.01.10.04 - 20250220 Release Notes
Removed links - sdcard had incorrect TI processor firmware
Update: TI SDK 10.01.10.04 - https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/10_01_10_04/exports/docs/devices/AM62X/linux/Release_Specific_Release_Notes.html
Update: Linux Kernel 6.6.58
Update: U-Boot 2024.04
Update: TI Processor Firmware v10.01.08 (Fiery Fox)
Note: Kernel: 1.4 Ghz support has been disabled due to Errata: 4.7
Fixed: Possibility of video not working on boot
Fixed: Overlay loading in u-boot
Fixed/Hack: Streaming 1080p from the OV5640 camera does not work
Note: Removed bmap from sdcard image to avoid balenaEtcher bug
- 10.00.07 - 20250211 Release Notes
AM62x:
Update: TI SDK 10.00.07.04 - https://downloads.ti.com/processor-sdk-linux/esd/AM62X/10_00_07_04/exports/docs/devices/AM62X/linux/Release_Specific_Release_Notes.html
Update: Linux Kernel 6.6.32
Update: TI Processor Firmware v10.00.08 (Fiery Fox)
Known Issue: Streaming 1080p from the OV5640 camera does not work
Note: Removed bmap from sdcard image to avoid balenaEtcher bug - 10.00.07 - 20241120 Release Notes
Update: TI Processor Firmware v10.00.08 (Fiery Fox) TI Indicates this update is critical
Enhancement: U-Boot: Will now search for overlays in both “/boot/dtb” and “/boot/dtb/ti”
Fixed: Kernel: TIDSS will no longer cause a rare rcu_preempt
Fixed: Kernel: Capturing from a MIPI camera will no longer cause a rare kernel panic
Fixed: Kernel: ti-sci-clk: Will no longer cause a recalc-rate error on boot
Fixed: Kernel: MMC tuning errors have been greatly reduced and will be handled if they occur
Known Issue: Possibility of video not working on boot
Note: An early 10.00.07 - 20241031 version was released, this was rereleased as the kernel hash didn't match the rebased commits pushed to support.criticallink.com
