Boot options¶
Section 5 of the AM62x TRM discusses the initialization process in detail. Here we will talk about how this process is implemented on the Critical Link MitySOM-AM62x. The MitySOM-AM62x brings all 16 of the boot mode pins out to the edge connector.
Signal | BM00 | BM01 | BM02 | BM03 | BM04 | BM05 | BM06 | BM07 | BM08 | BM09 | BM10 | BM11 | BM12 | BM13 | BM14 | BM15 |
Pin | 154 | 148 | 150 | 152 | 156 | 144 | 146 | 142 | 155 | 157 | 153 | 149 | 151 | 147 | 145 | 143 |
As these signals are pin-muxed with other functions, care must be taken with regard to pull-up resistors and any signal integrity requirements imposed by the other functions, if used.
Note that the BM00, BM01, and BM02 pins are permanently set on the SOM using 10k pullup/pulldown resistors:
BOOTMODE Pin | SOM Configuration (fixed) |
BM00 | 1 |
BM01 | 1 |
BM02 | 0 |
On the Critical Link MitySOM-AM62x baseboard, the remaining BOOTMODE pins are mapped to two banks (SW1 and SW2) of 8 dip switches to allow maximum flexibility in choosing the boot mode.
SW1 BM3-7 Switch # | Corresponding BOOTMODE PIN |
1,2,3 | NOT CONNECTED |
4 | BM03 |
5 | BM04 |
6,7,8 | BM05, BM06, BM07 |
SW2 BM8-15 Switch # | Corresponding BOOTMODE PIN |
1 | BM08 |
2 | BM09 |
3,4,5,6,7,8 | BM10, BM11, BM12, BM13, BM14, BM15 |
Critical Link Evaluation Board Boot Settings¶
The Critical Link MitySoM-AM62xx Development Board (CLPN 80-001617) provides an array of interfaces capable of supporting booting the AM62x module. Boot mode option settings can be found in the "Primary Boot Mode Selection" table in the TRM.
Boot source configurations | |
Micro-SD boot | Booting the MitySOM-AM62x from SD card |
Octal-SPI boot | Booting the MitySOM-AM62x from the on-board OSPI/QSPI device1 |
eMMC boot | Booting the MitySOM-AM62x from the on-board eMMC1 |
DFU boot | Booting the MitySOM-AM62x over USB through DFU |
Network boot | Booting the MitySOM-AM62x from a network server |
Snagboot | Booting and flashing the MitySOM-AM62 platform with snagboot |
UART | Booting the MitySOM-AM62x over UART |
1 OSPI/QSPI and eMMC are optional devices on the MitySOM-AM62x, please see https://www.criticallink.com/product/mitysom-am62/ for ordering options
