Example GPIO¶
The reference filesystem includes libgpiod and the tool utilities that can be run from the command line to access GPIO pins:
- gpiodetect - list all gpiochips present on the system, their names, labels
and number of GPIO lines
- gpioinfo - list lines, their gpiochip, offset, name, and direction, and
if in use then the consumer name and any other configured
attributes, such as active state, bias, drive, edge detection
and debounce period
- gpioget - read values of specified GPIO lines
- gpioset - set values of specified GPIO lines, holding the lines until the
process is killed or otherwise exits
- gpiomon - wait for edge events on GPIO lines, specify which edges to watch
for, how many events to process before exiting, or if the events
should be reported to the console
- gpionotify - wait for changed to the info for GPIO lines, specify which
changes to watch for, how many events to process before exiting,
or if the events should be reported to the console
Detailed GPIO Example | |
User-level GPIO Access | This example demonstrates how to access a GPIO at user-level using the "sysfs" capability. |
