Wiki Map
Pages with TODO tag
Pages with REVIEW tag
Linux App Visual Studio Code
Objective
This wiki page will describe how to setup Visual Studio Code so it can be used to build and debug an ARM Linux user-level program on the AM62x.
General setup
Hello World Example
  • Create a project directory using the attached hello.tar.gz file.
    • Source file is just main.c with hello world
    • Note these example files
      • .vscode/tasks.json
      • .vscode/launch.json
      • build.sh
      • hello.pro
  • Start VScode.
    • Connect to your development host
    • Start a terminal view in VScode on the development host
      cd <project_directory>/hello
      code .
  • Build the app for debug mode. ctrl-shift-B, select build debug
  • copy to target
    • Start a Terminal View. Main Menu->Terminal->New Terminal
      scp debug/hello target_62x:
  • run on target
    ssh target_62x ./hello
  • Debug the program
    • start gdbserver on target
      ssh target_62x gdbserver :10000 ./hello
    • start debug session
      • Press the debug icon on left. (Triangle pointing to right with bug on lower left)
      • In the Run and debug combo box at top, select Attach to target_62x
      • Should stop with arrow at the printf line.
      • Step over the printf
      • Step over the fflush
      • Should see Hello on the terminal view where gdbserver was started
      • Click the disconnect icon or shift+F5
  • VSCode debugger quirks
    • Only plant or remove breakpoints when the target is stopped, not when the target is running.
    • Only disconnect a debug session when the target is stopped.
    • Doing these operations while the target is running will cause confusion. You may have to kill the gdbserver manually on the target and you will have to start a new debug session.
Summary
A sample debug session with a simple hello world project has been demonstrated.
