M4 hello world patches for use with remoteproc
Add this new header file resource_table_no_ipc.h*
Add the lines shown in red
modify main.c
Note that you must use the modified resource_table_no_ipc.h attached below.
    #include "FreeRTOS.h"
    #include "task.h"
    /* add a resource table to the project so it can be loaded by Linux RemoteProc driver */
#include "resource_table_no_ipc.h"
#define MAIN_TASK_PRI (configMAX_PRIORITIES-1)
AM62x only
modify linker.cmd
     .sysmem: {} palign(8) > M4F_IRAM     /* This is where the malloc heap goes */
     .stack:  {} palign(8) > M4F_IRAM     /* This is where the main() stack goes */
    GROUP {
// This is the resource table used by linux to know where the IPC "VRINGs" are located
.resource_table: {} palign(4096)
} > DDR_0
/* Sections needed for C++ projects */
.ARM.exidx: {} palign(8) > M4F_IRAM // Needed for C++ exception handling
.init_array: {} palign(8) > M4F_IRAM // Contains function pointers called before main
and
     M4F_IRAM : ORIGIN = 0x00000200 , LENGTH = 0x0002FE00
     M4F_DRAM : ORIGIN = 0x00030000 , LENGTH = 0x00010000
    // when using multi-core application's i.e. more than one R5F/M4F active, make sure
// this memory does not overlap with R5Fs
// Resource table must be placed at the start of DDR_0 when M4 core is early booting with Linux
DDR_0 : ORIGIN = 0x9CC00000 , LENGTH = 0x1000
